Add a batch query endpoint to Sonar
What I’m requesting: A single API call that accepts an array of independent queries and returns an array of results — e.g. POST /sonar/batch with { “queries”: […] } → { “results”: [ { query, answer, citations }, … ] }, with per-item status so one failed query doesn’t fail the whole batch.
Use case: Some user actions in our app trigger several independent Sonar queries at the same time rather than a single query. This produces short bursts of concurrent calls instead of steady traffic.
Why it matters: Batching these into one request would make request volume predictable, reduce per-call overhead and round-trips, simplify retry/backoff handling, and make latency and cost easier to forecast as usage grows. Bursty concurrency is the hardest part of capacity planning today.
Current limitation or workaround: We currently issue N separate concurrent calls and manage our own concurrency, retries, and rate-limit backoff around the burst. It works but is brittle and makes throughput and cost hard to predict.
Suggested API behavior:
POST /sonar/batch
{ “model”: “sonar”, “queries”: [“…”, “…”] }
→ 200 { “results”: [ { “query”: “…”, “answer”: “…”, “citations”: […], "
status": “ok” } ] }
Optional shared parameters (e.g. recency filter) applied across the batch.
Example: Request: { “queries”: [“<query 1>”, “<query 2>”] } Response: { “results”: [ { query:“<query 1>”, answer:“…”, citations:[…] }, { query:“<query 2>”, answer:“…”, citations:[…] } ] }
Expected vs current: Expected — one call returns all results with per-item citations and status. Current — one call per query; bursty concurrency we orchestrate ourselves.
+1. Besides capacity planning there’s a cost reason too: the batch APIs at other providers usually run at about half the price of sync calls in exchange for a delay, and a Sonar batch endpoint with per-item status could open the same trade for workloads that don’t need an answer in seconds. (Disclosure: I edit aicost.tools, so batch discounts are something I track.) emfedsci, do your bursts need answers in real time, or could some of them wait a few minutes?
