Agent API: prompt caching for openai/gpt-6.1-sol (cache writes billed, breakpoints dropped)
Hello Perplexity API team,
we use the Agent API (POST /v1/agent) with openai/gpt-6.1-sol for long
structured-output calls (60–90k input tokens). While checking our costs we
found three things about prompt caching that the docs do not cover. Test
requests from 2026-10-20, about 10:55–10:59 UTC, are listed below.
  1. Cache writes are billed but not documented
    Every gpt-6.1-sol request bills the full input as
    cache_creation_input_tokens (cost.cache_creation_cost), which works out to
    1.25x the input price ($2.50 instead of $2.00 per 1M tokens). The Agent API
    Models page lists input, output and cache-read prices only, with no cache-write
    price. Across 215 production-like requests we were billed for 5.29M written
    tokens and 1,039 read tokens.
  • Is the cache-write surcharge intended?
  • Can we opt out of cache writes for requests that will not be reused?
    Example: resp_2ea3584b-e620-4b9c-83b5-252315d591ec
  1. Explicit cache breakpoints are dropped
    OpenAI documents prompt_cache_options (mode “explicit”) and
    prompt_cache_breakpoint on input_text parts for GPT-5.6 and later. The Agent
    API accepts both without an error, but the response echoes
    prompt_cache_options as null and still writes the full input. Mode “explicit”
    with no breakpoint should write nothing, but it still writes everything.
    Because of this, a follow-up request that resends the same ~60–90k-token
    prefix plus new turns (our validation retries) never reads from the cache.
  • Do you plan to pass OpenAI’s explicit cache breakpoints through?
  • If not, is there another way to get a cache read on a shared prefix when
    new turns are appended?
    Examples:
    resp_d9f8439a-7fce-4d0b-94f7-a406935fbb0b (explicit breakpoint, 0 read)
    resp_1c3168c9-f86a-48fa-a735-3e41f9097a38 (same prefix + 2 turns, 0 read)
  1. prompt_cache_key for OpenAI models
    Identical requests without prompt_cache_key never read from the cache (0 of
    3). With prompt_cache_key they did (3 of 3, about 95% cheaper). The field is
    not in the API reference schema; it appears only in the changelog under
    presets.
  • Is prompt_cache_key the supported way to get cache reads for OpenAI models?
  • Does it affect routing?
  • Are there limits we should know about, such as the number of keys or
    requests per key?
    Examples:
    resp_27f8e738-58e4-4c44-a7d1-1de857c37331 (no key, 0 read)
    resp_d1a9796f-76f6-4f1c-bddd-792645d6704a (with key, 11,926 tokens read)
    Thank you,
    Marius
Your numbers make the problem pretty stark: 5.29M tokens written against about a thousand read means you’re paying the 1.25x surcharge for a cache that basically never hits. Even before the team answers on opting out, I’d check whether anything variable sits at the very start of the input (a timestamp, a request id, or the per-call document placed ahead of the schema), because moving the static instructions and JSON schema to the front is often what turns writes into reads. (Disclosure: I edit aicost.tools, so undocumented cache-write pricing is exactly the kind of line item we chase.) Are your 60–90k inputs mostly shared context, or mostly unique per call?
