Hi guys, I’d like to request an API function inside your (Max) account.
The API should be able to retrieve the current balance of tokens (for Computer), full history of token usage per projects and tasks, and eventually, control over refill flow (limit per refill or per day/week/month).
I think it would be useful to all users, especially Max and Enterprise ones like myself. And it shouldn’t be hard for you to implement it.
Looking forward to hearing back from you all and seeing this implemented.
Hi @paulfxyz,
Thank you for your feature request! I have forwarded it to the correct team. Enterprise accounts now have an Analytics API endpoint for member usage information - Analytics API - Perplexity
I appreciate your suggestion.
Andrew
Thanks, Andrew. I hope Max and other tiers will have it shortly as well.
Hi, I’m now Enterprise Max user and I still do not see any clear APi function to check an account’s credit balance and other credit-related data. I think this needs to go as P1 now.
Hey @andrewmadson-pplx
The docs are explicit: this API only exposes credits USED (historical consumption), not credits REMAINING (current balance). There is no documented endpoint for “current balance” or “credits left”. And:
Buckets are complete UTC grids only — the in-progress bucket is never returned. With 1h you’re always looking at the last fully-closed hour, not “right now”.
The analytics store syncs periodically, not in real time.
Time windows capped at 90 days per request.
So you can’t literally show 19.54K remaining. But you absolutely can build things people actually want. Or did I just upgraded to Enterprise Max to no avail?
