Can't use high reasoning effort with anthropic/claude-opus-4-5
:bug: Describe the Bug
When calling “anthropic/claude-opus-4-5" model via agentic research API with “high” reasoning effort the API returns 400 “invalid request” error. It works without issues with reasoning effort set to “low” and “medium”.
API request completed successfully.
:cross_mark: Actual Behavior
API returned 400 “invalid request” error.
$ export PERPLEXITY_API_KEY="...key value..."
$ curl https://api.perplexity.ai/v1/responses \
  -H "Authorization: Bearer $PERPLEXITY_API_KEY" \
  -H "Content-Type: application/json" \
  -d '{
    "model": "anthropic/claude-opus-4-5",
    "input": "calculate 2+2=",
    "reasoning": {
      "effort": "high"
Request:
    "reasoning": {
        "effort": "high"
response:
{"error":{"message":"invalid request","type":"invalid_request","code":400}}
  • API Version: Current (no idea how to check)
  • SDK (if applicable): N/A
  • Operating System: Linux
Trying all three reasoning effort values:
$ curl https://api.perplexity.ai/v1/responses   -H "Authorization: Bearer $PERPLEXITY_API_KEY"   -H "Content-Type: application/json"   -d '{
    "reasoning": {
      "effort": "low"
{"created_at":1770384358,"id":"resp_9d79fcd9-a36c-4cdf-8747-4ecd3a643c38","model":"anthropic/claude-opus-4-5","object":"response","output":[{"content":[{"text":"2 + 2 = **4**","type":"output_text"}],"id":"msg_11c3891e-87ef-4180-9ca8-978706bc8f1b","role":"assistant","status":"completed","type":"message"}],"status":"completed","usage":{"cost":{"currency":"USD","input_cost":0.0005,"output_cost":0.00145,"total_cost":0.00195},"input_tokens":99,"output_tokens":58,"total_tokens":157}}
    "reasoning": {
      "effort": "medium"
{"created_at":1770384371,"id":"resp_43b3499f-f2be-4e52-8ada-1a5a7a73ecea","model":"anthropic/claude-opus-4-5","object":"response","output":[{"content":[{"text":"2 + 2 = **4**","type":"output_text"}],"id":"msg_d43ef1f1-6eee-4937-91ed-80748b52b079","role":"assistant","status":"completed","type":"message"}],"status":"completed","usage":{"cost":{"currency":"USD","input_cost":0.0005,"output_cost":0.00125,"total_cost":0.00175},"input_tokens":99,"output_tokens":50,"total_tokens":149}}
    "reasoning": {
      "effort": "high"
Il passaggio da lordo a netto rappresenta il processo attraverso il quale si determina l’importo effettivamente ricevuto dal lavoratore a partire dalla retribuzione lorda. Durante questo calcolo vengono sottratti i contributi previdenziali, le imposte sul reddito e le eventuali addizionali locali previste dalla normativa fiscale.
