History dates changing after bulk category change in Library/Spaces
:bug: Describe the Bug
I just categorized about a years worth of searches and the old (actual) search date was overwritten with todays date.
I would have expected searches that were not amended to have their date unchanged.
:cross_mark: Actual Behavior
dates were overwritten without new searches being made on old threads
  1. take an item in your history (library)
  2. categorize it or change the categorization
  3. watch the date change
  1. API Version: Not using API (using Perplexity web app only)
  2. SDK (if applicable): None
  3. Operating System: Windows 11
:memo: Additional Context
dates should be part of all answers to aid debugging and data management. you are generally very weak on database management capability.
Hey — this forum is specifically for the Perplexity API (Sonar models, Search API, Agent API, SDKs, billing/credits). For issues with the Perplexity consumer product (web app, mobile, Spaces, Library), the best route is the in-app help or support at support.perplexity.ai.
Closing this thread, but feel free to open a new one if you have an API-related question.
