Feature Request
Native IMDb connector in Perplexity/Comet that keeps user’s watch history and ratings in sync automatically, so movie recommendations are personalized and never include titles already watched.
Problem Statement
When a user asks Perplexity/Comet for movie recommendations, the suggestions are random and vague, with titles already seen.
There is no native connector in Perplexity’s “Connectors” area (like Gmail/Calendar) that can read this data and use it to personalize or filter recommendations.
Users don’t want to manage exports, files, or manual lists; just want to click “Connect IMDb” once and have everything stay up to date in the background.
Proposed Solution
Add IMDb as a first‑class Connector in the Perplexity account “Connectors” section, alongside Gmail and Google Calendar.
User flow:
Go to Settings → Connectors.
Click “Connect IMDb”.
Go through IMDb’s OAuth/login flow and grant read access to watchlist/ratings/history.
From then on, Perplexity/Comet has a continuously updated, private view of the content.
Behavior:
When asked for movie suggestions, Perplexity automatically:
Excludes anything in the watched history.
Can optionally bias toward genres, years, and ratings the user tends to enjoy, inferred from that history.
No extra prompts, no copy‑pasting lists, no re‑exports; just like the Gmail/Calendar connector where, once enabled, queries can transparently pull from email/calendar.
Scope:
Read‑only access to my IMDb lists is sufficient; Perplexity does not need to modify anything in IMDb, potentially it could add titles to the watch list, rate and everything else.
If a full IMDb connector is not immediately feasible, Perplexity could still prepare the connector infrastructure and later plug in alternative sources (e.g., Letterboxd, Trakt) using the same “Connect” pattern.
API Impact
Affected components:
Chat completions / conversations that generate recommendations.
Retrieval / search if Perplexity exposes recommendation or personalization APIs.
Model scope:
- Especially relevant for Sonar Deep Research and any recommendation‑heavy workflows.
Possible API changes:
- Introduce a generic concept like a
user_profile_connectorormedia_history_connectorthat the API can reference (e.g.,source: "imdb"), so the backend can inject “already watched” constraints and preference signals without the client sending raw lists each time.
Alternatives Considered
Manually exporting IMDb to CSV and pasting it into prompts or opening it in a Comet tab.
- This is fragile, token‑heavy, and would require the user to repeat the process after every change in IMDb, which is exactly what a connector is meant to avoid.
Periodically re‑uploading updated CSV files to some internal “library” space.
- Still too much friction; the whole point is to have a one‑click, OAuth‑style connection like Gmail/Calendar, where data stays in sync automatically.
Additional Context
This would showcase Perplexity’s connector strategy beyond productivity (email/calendar) and into entertainment and personalization, which is a huge real‑world use case.
The same pattern could later generalize to other media services (Letterboxd, Trakt, TV Time, etc.), using the same “Connect once, always up to date” model.
