Multi‑ticker / batching support for financial research
:rocket: Feature Request
Better support for batching / multi‑entity queries (e.g., multiple financial tickers) in the Perplexity API, so we can efficiently run many similar research tasks without hitting rate limits so quickly.
:magnifying_glass_tilted_left: Problem Statement
Our production system uses the Perplexity (Sonar) API to generate brief research summaries for >1000 stock tickers.
Currently, we have to send one request per ticker (>1000 calls per refresh), which hits rate limits and creates a major performance bottleneck.
:light_bulb: Proposed Solution
  • Provide first‑class support or clear best practices for multi‑entity queries, such as:
    • A way to pass a list of entities (tickers) and receive clearly segmented per‑ticker results.
    • Or documented, recommended batch sizes and patterns (e.g., N tickers per request) with examples and structured output (e.g., JSON array of per‑ticker summaries).
:pushpin: API Impact
  • Affects: chat completions for web‑search‑enabled models (e.g., Sonar Pro / Deep Research).
  • May require: Either a new optional parameter for entity lists, or official guidance + examples on how to safely batch multiple entities in a single prompt.
:counterclockwise_arrows_button: Alternatives Considered
  • One call per ticker with throttling: hits rate limits and is slow at our scale.
  • Stuffing many tickers into one prompt: responses become shallow, sometimes truncated, and hard to parse per symbol.
:paperclip: Additional Context
  • Universe: >1000 tickers; goal is concise, up‑to‑date qualitative summaries, not raw price data.
  • We’d also appreciate any guidance on appropriate rate‑limit tiers or enterprise options for this kind of workload.
