Python API examples not correct
:bug: Python API search_recency_filter not supported
The documentation shows a search_recency_filter arg in the Python API:
# For general information and current events
web_search = client.search.create(
    query="latest tech news",
    search_mode="web",
    search_recency_filter="day"
I expect the parameter to be in the API
:cross_mark: Actual Behavior
TypeError: SearchResource.create() got an unexpected keyword argument ‘search_recency_filter’
  1. Call the API in the documented way.
  2. Observe the unexpected behavior.
  • API Version: ?
  • SDK (if applicable): 0.11.0
  • Operating System: Linux
FYI, this is the same with the TypeScript SDK, it seems that in general search_recency_filter is not implemented in the API endpoint. The API docs say it is, but the API reference does not list it. And the SDK typings do not have it either.
And there are more discrepancies between docs and implementation, started to collect them here:
Similar issue here. Just want to note that search_domain_filterand other Date Range Filtering related arguments are also not working.
Hey all! We’ve made some fixes regarding this, is anyone still experiencing any issues with the above filters?
