Describe the Bug
Sonar-Deep-Research shows the same source/url as if they were different sources in search_results.
Expected Behavior
Each source should be unique and not appear duplicated.
Actual Behavior
search_results sometimes shows the same url/source more than once, as if they were different sources.
Steps to Reproduce
- Call the API with the contents shown below.
- Sometimes the search_results object will have duplicated values of sources/url. It doesnβt happen everytime, and I couldnβt find the reason why, since the request is always the same.
API Request & Response (if applicable)
curl -X POST "https://api.perplexity.ai/chat/completions" \
-H "Authorization: <Hidden>" \
-H "Content-Type: application/json" \
-H "Accept: application/json,text/html,application/xhtml+xml,application/xml,text/*;q=0.9, image/*;q=0.8, */*;q=0.7" \
--compressed \
--location \
--max-time 300 \
-d '{
"model": "sonar-deep-research",
"messages": [
"role": "user",
"content": "What are the main challenges in measuring fugitive emissions in agriculture?"
Environment
- API Version: sonar-deep-research
Logs or Screenshots (if applicable)
Additional Context
