[SOLVED] Search API suddenly stops returning results when using search_domain_filter=["sec.gov"]
:bug: Describe the Bug
So around 6-8 hours ago I was still able to retrieve search results when using search_domain_filter=[``sec.gov``]. However, I recently tested out the API and found empty results. This has been going on for about 3 hours. Any help would be appreciated!
Found search results.
:cross_mark: Actual Behavior
No search results found.
Run the following code with Perplexity’s Python SDK
client = Perplexity(api_key=os.getenv("PPLX_API_KEY"))
search = client.search.create(
    query="Tesla 2024 10K",
        "sec.gov"
    max_results=10,
    max_tokens_per_page=1024
if not search.results:
    print("No results found")
else:
    for result in search.results:
        print(f"{result.title}: {result.url}")
Request
curl https://api.perplexity.ai/search   -H "Authorization: Bearer <API_KEY>"   -H "Content-Type: application/json"   -d '{
    "query": "Apple 10-K 2024", "search_domain_filter": ["sec.gov"]
  }' | jq
Response
  "results": [],
  "id": "c7befd33-11f4-489a-bab2-c84c0e06116e"
  • API Version: Search API
  • SDK (if applicable): Python SDK v0.17.0
  • Operating System: Ubuntu 24.04
N/A
:memo: Additional Context
N/A
Just tested it now, it has gone back to normal.
If possible I still would like to know what caused it. Thank you.
