sonar-pro and sonar-reasoning-pro returning empty search_results across all queries (2026-05-01)
Reporter: slinn201@gmail.com
Date filed: 2026-05-01 (Friday)
Affected models: sonar-pro, sonar-reasoning-pro
Severity: Service-impacting — automated job-discovery pipeline returning 0 results for all categories all day
Summary
Sonar’s web-search step is no longer feeding search results to the language model for our API calls today (2026-05-01). The model receives an empty <search_results> block (or “None”) and correctly responds with []. This was visible in sonar-pro only as completion_tokens=1 and an empty content body, but became fully diagnosable when we swapped to sonar-reasoning-pro, which exposed <think> traces in which the model itself states: “the search_results section is empty/None… There are NO search results provided.”
The issue affects 3 of 4 of our prompt categories with searchResults=0 and 1 category with searchResults=1 (returning a single irrelevant URL: https://mmwlegal.com/author/mmwmmwlegal-com/). The same prompts and configuration worked normally earlier this morning (6:22 AM CDT) — at least for one of the four categories.
We suspect either an account-level search degradation or a broader Sonar search-pipeline incident not currently reflected on status.perplexity.com.
Reproducer
POST https://api.perplexity.ai/chat/completions with body:
  "model": "sonar-pro",
  "messages": [
    { "role": "system", "content": "You are a thorough job-search assistant. Search multiple job boards (LinkedIn, Indeed, BuiltIn, company career sites) and return real currently-live postings that match the user's criteria. Return ONLY a valid JSON array of job objects — no commentary, no markdown fences, no prose outside the JSON. Only the 5 REQUIRED fields are mandatory; for OPTIONAL fields, return \"\" (empty string) when unknown rather than dropping the posting. Prefer returning 1–3 imperfect-but-real matches over returning []. Only return [] if you genuinely cannot find anything after searching." },
    { "role": "user", "content": "Find Asset-Based Lending (ABL) analyst-level positions in the United States across THREE title families... [full prompt available on request — ~1600 prompt tokens of named-employer anchors and title-phrase enumerations]" }
  "temperature": 0.3,
  "search_recency_filter": "month",
  "web_search_options": { "search_context_size": "medium" }
Observed behavior
Across 4 runs in 30 minutes spanning 3 different configurations and 2 models, all 4 prompt categories returned the same broken pattern. Detail below.
Diagnostic field summary (sonar-pro)
Run Time (CDT) Config Source finish_reason completion_tokens citations search_results content
1 06:22 temp=0.3, context=medium, no max_tokens ABL stop 1 0 0 "[]"
1 06:22 (same) SF stop 1 0 0 "[]"
1 06:22 (same) FPA stop 1 0 0 "[]"
1 06:22 (same) IBR stop 1208 (real) (real) 5 real jobs :white_check_mark:
2 06:43 temp=0, context=high, no max_tokens ABL stop 1 0 0 "[]"
2 06:43 (same) SF stop 1 8 8 "[]" (cited Merriam-Webster for verb “find”)
2 06:43 (same) FPA stop 1 1 1 "[]" (mmwlegal.com)
2 06:43 (same) IBR stop 1 0 0 "[]"
3 06:55 temp=0.2, context=high, max_tokens=4000 ABL stop 1 0 0 "[]"
3 06:55 (same) SF stop 1 0 0 "[]"
3 06:55 (same) FPA stop 5 1 1 ```json\n[]\n``` (mmwlegal.com)
3 06:55 (same) IBR stop 1 0 0 "[]"
4 07:07 temp=0.3, context=medium, no max_tokens (= run 1 config) ABL stop 1 0 0 "[]"
4 07:07 (same) SF stop 1 0 0 "[]"
4 07:07 (same) FPA stop 1 1 1 "[]" (mmwlegal.com)
4 07:07 (same) IBR stop 1 0 0 "[]"
Critical: Run 4 used the exact same configuration as run 1, in which IBR succeeded — but in run 4 IBR returned the same broken [] as everything else. The only variable that changed was time of day and Sonar API behavior.
Diagnostic field summary (sonar-reasoning-pro)
Run Time (CDT) Source finish_reason completion_tokens citations search_results
5 07:18 ABL stop 626 0 0
5 07:18 SF stop 469 0 0
5 07:18 FPA stop 607 1 1 (mmwlegal.com)
5 07:18 IBR stop 620 0 0
The reasoning model’s <think> traces are the smoking gun. Verbatim excerpts from choices[0].message.content (first ~500 chars):
ABL:
<think>
The user is asking me to search for ABL (Asset-Based Lending) analyst-level positions in the United States across three title families. However, looking at the search results provided, I see:
<search_results>
Search results:
None
</search_results>
There are NO search results provided. The search_results section is empty/None.
SF:
<think>
...However, I've been given search results that are empty (no search results provided). The instruction says "None" under search_results.
FPA:
<think>
...the "search results" provided to me are from a law firm website (mmwlegal.com) discussing legal topics like company directors, shareholder disputes, surrogacy, and insolvency. These search results are completely irrelevant to the FP&A job search request.
IBR:
<think>
...The search results provided are "None" - so I need to conduct a search myself.
However, I'm an AI assistant and I don't have the ability to browse the internet in real-time, access LinkedIn, Indeed, Builtin, company career sites, or any other live job boards.
The model is explicitly stating it received no search results. This points to the search-retrieval step of Sonar — not the language-model step — being the failing component.
Things we ruled out on our side
  1. Prompt content — IBR’s prompt was unchanged across runs 1–5; it worked in run 1 and broke in runs 2–5.
  2. Temperature — tested 0, 0.2, 0.3 with same result.
  3. max_tokens — tested with and without an explicit 4000-token budget.
  4. search_context_size — tested both medium and high.
  5. Model — tested both sonar-pro and sonar-reasoning-pro.
  6. search_recency_filter — kept at "month" throughout; not changed.
  7. API key / auth — all responses returned status=200 with no auth or rate-limit errors.
  8. Account/billing — no plan changes today.
Things we suspect are on Perplexity’s side
  1. Search retrieval pipeline returning empty results to the LLM. The reasoning-model <think> traces directly evidence this.
  2. The recurring mmwlegal.com/author/mmwmmwlegal-com/ citation appearing in 3 of 5 runs across different prompts is suspicious — looks like a stale cache hit or a bug where one fixture leaks into unrelated queries.
  3. The status page (status.perplexity.com) shows no incidents, but the historical pattern of sonar-pro runs returning empty all week (per our cron history) suggests this may be a slow degradation rather than an acute outage.
Request
  1. Investigate whether the search-retrieval step of Sonar is failing to populate <search_results> for our account on sonar-pro and sonar-reasoning-pro.
  2. Confirm whether other accounts are seeing the same pattern.
  3. Advise whether there is a workaround we can apply on the request side (different parameter combination, different model, etc.) that would re-engage the search step.
    Happy to enable additional verbose logging or share full request/response payloads for any of the 16+ failed calls captured today.
Pre-flight checklist
  • This is about the Perplexity API, not the Perplexity app, Comet, or web UI.
  • I have removed API keys, secrets, and private data.
  • I have included enough information for someone else to reproduce the issue.
Bug type
  • Error response or failed request
  • Incorrect or unexpected model output
  • Missing, invalid, or stale citations/search results
  • Streaming issue
  • Structured output or JSON schema issue
  • SDK issue
  • Billing, credits, or rate limit issue
  • Dashboard, API key, or auth issue
  • Other API bug
Affected API area
  • Agent API
  • Search API
  • Sonar API
  • Embeddings API
  • SDKs
  • Billing or credits
  • Not sure
Summary
Expected behavior
Actual behavior
Minimal reproduction
Response or error
Request details
  • Endpoint:
  • Model or preset:
  • SDK/language/version:
  • Request ID:
  • Approximate time and timezone:
  • Consistent or intermittent:
Additional context
