Use Perplexity for SQL Apps
Hi,
I am doing a course on Deeplearning.ai: Building Your Own Database Agent - DeepLearning.AI
My goal is to make an SQL app using the perplexity app. However, when converting the code that is provided in the course material I am getting stuck completely. The course is using OPENAI API.
Do you know about an example of a database app that I can use so that I can practice and learn SQL apps using Perpelxiity API?
Thanks,
Naveen
