Using the Sonar API to answer visitor questions on a small public land-record help site — where do I start?
I run a small public help site for Karnataka land records — the current version is live at bhoomi — and I would like to add a simple question box so visitors can ask, in plain language, how to check their RTC or what a survey number means.
Start with the Agent API, not Sonar. Sonar Chat Completions support ended on September 27, 2026. Send each visitor question from your server to POST https://api.perplexity.ai/v1/agent with effort: “fast”, and add the web_search tool with search_domain_filter set to official sources such as landrecords.karnataka.gov.in. Show the source links that come back with each answer.
