Feature Request
Allow user to specify staged, conditional searches of uploaded files, rather than searching all of them all at once.
Problem Statement
In Perplexity Spaces there is no current feature that allows the user to enforces a staged, conditional search at the file selection level. All included files are always potentially searched, regardless of instruction text. In this case of a large library of files, this limits the efficiency of the searches and cause the context window to close quickly.
Proposed Solution
Allow user to specify how the files should be searched., e.g. “search only summaries, then if nothing found, search originals”)
Allow files to be toggled on/off so that user can specify which files they want searched without having to completely remove and then re-upload them.
API Impact
- Which API component is affected? retrieval
- Is this related to a specific model? no
- Would this require new API parameters or changes to existing ones?
Alternatives Considered
Have you explored any workarounds? Yes.
If so, what were they, and why are they insufficient? As a first step the AI searches all files first, then implements user’s instructions, so telling it to search only some of the files is a useless instruction.
Additional Context
Add any other relevant information, links, or screenshots that can help us better understand your request.
For direct inquiries, please reach out to api@perplexity.ai
