Billing auto recharge form errors
:bug: Describe the Bug
When I update the auto recharge, it requires a minimum of $50 now. Used to accept $5.
Now when I switch auto to off, then click Save, it cannot save, always shows and error and the form setting is not updated.
https://console.perplexity.ai/group/xxxxxxx/billing
Seems like three issues:
  • Minimum recharge for me is now $50
  • Cannot switch auto recharge off (error on save, settings not updated)
  • Auto recharged another $50 when my balance dropped by a tiny amount ~S0.50
  • I can set minimum balance of $5 before recharge
  • I can switch off auto recharge
:cross_mark: Actual Behavior
  • Error on save when set auto recharge to off
  • Error message when enter $2 or $5 as minimum recharge “Amount too low. Please enter an amount of at least $50.”
  1. Login to https://console.perplexity.ai/
  2. Click on Billing, then
  3. Click “Change preferences”, then
  4. Update preferences per above, then
  5. Click Save,
  6. Error message displayed top right of screen “Error. Please try again.”
  • API Version: [e.g., sonar-3.1]
  • SDK (if applicable): [e.g., Python SDK v0.5]
  • Operating System: [e.g., MacOS, Linux, Windows]
:memo: Additional Context
Hey @Matt_McFedries — the $50 minimum recharge amount is a recent change to the billing system, so that part is working as intended.
However, the issues with not being able to disable auto-recharge (save error) and the unexpected recharge trigger on a ~$0.50 balance drop are worth looking into. Please email api@perplexity.ai with your account details and reference this thread — the billing team can help sort out both of those issues directly.
