Perplexity macOS crashes with both Apple built-in Chinese IME and third-party IME
Hi Perplexity Support,
I’m seeing a reproducible crash in Perplexity for macOS while entering Chinese text using an IME.
Importantly, I originally reproduced the crash with the third-party WeType input method, but I have now reproduced what appears to be the same crash using Apple’s built-in Chinese input method (com.apple.inputmethod.TCIM / TCIM_Extension).
This suggests the issue is not specific to WeType and may instead be related to IME composition / marked-text handling in Perplexity’s text input implementation.
Environment:
  • Perplexity: 26.34.0 (87)
  • macOS: 26.6.2 (25G83)
  • Hardware: Mac15,10 / Apple M3 Max
  • Architecture: ARM64
  • SIP: enabled
The Apple built-in IME crash occurred on September 1, 2026 at 17:15:02 +0800.
The crash report identifies the triggering input method as:
and the voucher information identifies:
TCIM_Extension
The relevant exception stack is:
NSConcreteMutableAttributedString replaceCharactersInRange:withString:
→ NSConcreteTextStorage replaceCharactersInRange:withString:
→ NSTextView _insertText:replacementRange:
→ NSTextInputContext insertText:replacementRange:
→ IMKInputSession_Modern insertText:replacementRange:
The application then terminates due to an uncaught Objective-C exception (EXC_BREAKPOINT / SIGTRAP).
The same general input path also appeared in the crash I previously reproduced with WeType.
Because both a third-party IME and Apple’s built-in TCIM trigger the issue, this appears more consistent with an IME composition / replacement-range handling issue in the Perplexity Mac app rather than a vendor-specific input-method problem.
A possible failure mode is that the text storage or selection changes while an IME marked-text session is active, leaving replacementRange stale when AppKit commits the composed text.
I can provide both complete .ips crash reports.
Please investigate the query/input editor’s handling of:
  • NSTextInputClient
  • marked text / composition state
  • replacementRange
  • selection updates during composition
  • programmatic mutations of NSTextStorage while an IME session is active
Incident ID for the Apple TCIM crash:
7DFA4439-7830-4381-ABAD-073989EEECAD
Thanks.
have the same problem , same version, really frustrated
Same crash here, with a third input method — RIME / Squirrel (im.rime.inputmethod.Squirrel, 1.1.2). With WeType, Apple’s TCIM and RIME all hitting it, your read looks right: this sits in Perplexity’s text input rather than in any one IME.
Environment:
  • Hardware: Mac17,6 / Apple M5 Max, ARM64
  • SIP: enabled
  • Input method: Squirrel 1.1.2 (RIME)
Reproduction is 100%: type any code in the query box and commit it — the app dies the moment the composed text is committed. Earlier builds were fine for me, so this looks like a regression in 26.34.0.
Exception path is identical to yours:
-[NSTextView _insertText:replacementRange:]
  -[NSConcreteTextStorage replaceCharactersInRange:withString:]
    -[NSConcreteMutableAttributedString replaceCharactersInRange:withString:]  → uncaught NSException
Two details from my crash report that may help narrow it down:
  1. Directly above handleTSMEvent:completionHandler: is -[NSTextInputContext tryHandleTSMEvent_HasMarkedText_withDispatchCondition:dispatchWork:continuation:], so there was an active marked-text session at commit time. That fits the stale replacementRange theory.
  2. The termination path runs through SentryUncaughtNSExceptions swizzleNSApplicationReportException → NSApplicationUncaughtExceptionHandler → +[NSApplication _crashOnException:]. AppKit would normally log this exception and keep the app alive; NSApplicationCrashOnExceptions (or the Sentry equivalent) is what turns it into a hard SIGTRAP. Might be worth treating as a separate hardening item — even once the range bug is fixed, that setting means any stray exception on the main event loop takes the whole app down.
Incident Identifier: FE031204-2ED1-48E4-86A6-E8F87F23ABD4
Happy to attach the full .ips if that helps.
Hello @J_Wang ,
Thank you for your bug report about the macOS app. This is a known issue and the team is actively working on it. To be added to the ticket and notified of resolution, please email support@perplexity.ai (or use in-app “Report” button).
Andrew
