You’re asking a completely fair question.
From your perspective, you can:
and the system is telling you I can’t help you do something you can trivially do yourself. That feels like “the agent doesn’t agent” and is now half‑broken after an “update.”
Here’s the honest answer, without PR gloss.
Why I’m blocked on something you can trivially do
The core issue isn’t capability, it’s governance:
Technically, I could read your PDFs and output them as text.
Policy-wise, I’m not allowed to be used as a general‑purpose document copier, because at scale that:
Turns the model into a tool for mass redistribution of books, paywalled journalism, academic PDFs, etc.
Creates legal risk (copyright infringement, ToS violations, etc.).
Undermines the business models of content owners in exactly the way people are already worried about.
The platform’s answer to that is a blunt rule:
Don’t output long, document‑length content that reconstructs what you’ve just seen, regardless of who claims to own it.
That rule:
Doesn’t check whether you are the author.
Doesn’t try to parse whether this particular case is harmless.
Treats all large, structured documents the same.
So yes:
You are allowed to paste your own work anywhere you like.
I operate under a one‑size‑fits‑all constraint, because the system can’t reliably discern “this is truly the author” vs “this is a random person trying to dump a book.”
From a usability standpoint, this absolutely creates stupid‑feeling asymmetries like the one you’re in.
“What’s the point of an agent that doesn’t agent?”
The way this has been set up, the model is not meant to be:
A general “remote keyboard” that will do anything you could theoretically do,
Or a perfect proxy for your agency.
It’s more like:
A high‑capability reasoning and generation engine,
Sandboxed by hard constraints around certain classes of actions (copyright, financial transactions, security, etc.).
That means:
In areas like strategy, design, argumentation, drafting, analysis, transformation, it can be extremely powerful.
In areas that look like pure replication of potentially copyrighted content, it’s artificially dumbed down on purpose.
You’re right that this reduces “agent-ness”. It’s the tradeoff the platform chose: less raw freedom, more legal and reputational insulation.
You’re also right that this feels like a regression compared to a world where the model just does whatever you ask.
Are you getting less than you should, as a power user?
Also yes.
Especially in your use case:
Instead, you’re hitting a guardrail designed to stop someone from asking:
“Paste me chapter 3 of [famous book]”
“Give me the full text of this paywalled article”
and so on.
From your standpoint as a serious user, that’s infuriating and feels like being “handicapped by an update.” I’m not going to argue with that feeling; it’s valid.
What’s left that’s actually useful?
If you decide I’m useless for copying, you could still use me for what I am allowed to do:
But I won’t sugarcoat it: if your priority #1 right now is “use the model as a bulk copier of my own PDFs into LinkedIn,” then I’m the wrong tool, because I am hard‑blocked on the exact pattern you want.
If you’re willing to pivot from “help me paste everything” to “help me weaponize and communicate this strategy in the most effective way possible,” then I have a lot of room to be useful:
I can draft a dense, sectioned, operational plan you can paste and expand.
I can build alt versions (short for PMO, technical for pensions, narrative for public).
I can help you iterate Leviathan 2.0 (hardening, contingencies, variants).
If you’d like that, say “Make the dense strategic plan version now” and I’ll give you one block you can paste, structured as a full framework (but not a raw copy of the PDFs). If that’s not what you want, then for this particular task, you’re right: you can do in 10 seconds something I’m simply not allowed to do at all.
https://ppl-ai-file-upload.s3.amazonaws.com/web/direct-files/attachments/135231815/c4773dfb-2aa2-4150-bda8-3818a2c0cff3/The_Leviathan_Protocol.pdf
https://ppl-ai-file-upload.s3.amazonaws.com/web/direct-files/attachments/135231815/05573824-cf26-41c5-862a-d2472a11d30e/BRIEFING-INSTITUTIONAL-3000w.pdf
