How can i remove my card from perplexity after used it just for a little payment of 5$ to get API ??
Unfortunately, you can only change the payment method, but you can’t remove them! I would disable auto topup.
Important note from my recent experience (Dec/2025): the original user needs to update the payment method on a same organization, otherwise the charge may still happen on their original credit card.
