Structured output is not structured
:bug: Describe the Bug
Structured output doesnt work stable - with one code and one environment it builds sometimes structured output and sometimes not. It works so even with structured code example from documentation.
Structured output works always.
:cross_mark: Actual Behavior
Structured output works unstable.
Run code from example multiple times (Structured Outputs Guide - Perplexity):
import requests
from pydantic import BaseModel
class AnswerFormat(BaseModel):
    first_name: str
    last_name: str
    year_of_birth: int
    num_seasons_in_nba: int
url = "https://api.perplexity.ai/chat/completions"
headers = {"Authorization": "Bearer YOUR_API_KEY"}
payload = {
    "model": "sonar",
    "messages": [
        {"role": "system", "content": "Be precise and concise."},
        {"role": "user", "content": (
            "Tell me about Michael Jordan. "
            "Please output a JSON object containing the following fields: "
            "first_name, last_name, year_of_birth, num_seasons_in_nba. "
    "response_format": {
		    "type": "json_schema",
        "json_schema": {"schema": AnswerFormat.model_json_schema()},
response = requests.post(url, headers=headers, json=payload).json()
print(response["choices"][0]["message"]["content"])
  • API Version: Current (model - sonar)
  • Pydantic version (used for BaseModel): 2.11.7
  • Operating System: Linux, Windows
Several runs of the code from the example:
PS C:\> & ... test.py
{ "first_name": "Michael", "last_name": "Jordan", "year_of_birth": 1963, "num_seasons_in_nba": 15 }
{"first_name":"Michael","last_name":"Jordan","year_of_birth":1963,"num_seasons_in_nba":15}
```json
Michael Jordan was born in 1963 and played 15 seasons in the NBA between 1984 and 2003[1][3][5].
PS C:\>
:memo: Additional Context
I’ve been using Structured Output in Perplexity for a long time, it stopped working recently
I am also encountering this issue
Same issue is happening for me today, now that i wanted to test my code before prod. WTF perplexity
Same. Used Perplexity structured output in production app and it now returns plaintext response more often than not. Seems to be completely ignoring the json schema provided to it. It worked well before this week.
Hey everyone! We apologize for the inconvenience. This issue should now be resolved. If anyone is still experiencing problems with structured outputs, please let us know with code samples and timestamps!
